RG-S5760C-48GT4XS-HP-X 48-Port GE Electrical Layer 3 Enterprise-Class PoE Core or Aggregation Switch, Four 10G Uplink Ports
  • Rich port types, 48 x 1000 Mbps Ethernet ports, PoE/PoE+ supported, and4 x 10G optical ports for uplink
Aggregation switch for small and medium-sized campus networks, with four 10G uplink optical ports for data transmission; 48 x 1000 Mbps Ethernet ports with auto-negotiation, PoE/PoE+ supported, providing high-speed network experience for short-distance services. Core switch for small and medium-sized enterprise networks, with high scalability, efficiency, and manageability, and device-level and link-level reliabilities for stable connectivity.
Tài liệu
RG-S5760C-24GT8XS-X
RG-S5760C-48GT4XS-X
RG-S5760C-24SFP8GT8XS-X
RG-S5760C-48SFP4XS-X
Two built-in fan modules
Three pluggable fan modules
Two pluggable fan modules
Two power modules
Management port
Expansion slot
426Mpps/600Mpps
406Mpps/600Mpps
426Mpps/600Mpps
406Mpps/600Mpps
406Mpps/600Mpps
880Gbps/7.92Tbps
880Gbps/7.92Tbps
880Gbps/7.92Tbps
880Gbps/7.92Tbps
880Gbps/7.92Tbps
mmu-enhance: 3,000
mmu-enhance: 3,000
mmu-enhance: 3,000
mmu-enhance: 3,000
mmu-enhance: 3,000
mmu-enhance: 1,500
mmu-enhance: 1,500
mmu-enhance: 1,500
mmu-enhance: 1,500
mmu-enhance: 1,500
In: 7,000
Out:1,500
Number of IGMP groups
Number of MLD groups
4.4 kg (9.70 lbs)
5.3 kg (11.68 lbs)
5.5 kg (12.13 lbs)
1.2 GHz dual-core CPU
Flash memory: 4 GB
SDRAM: 1 GB
Flash memory: 4 GB
SDRAM: 2 GB
1.2MB
Without PoE load: ≤ 110 W
With PoE full load: ≤ 1,590 W
RG-PA70IB: 70 W
RG-PA150I-F: 150 W
RG-PA70IB: 70 W
RG-PA150I-F: 150 W
RG-PA150I-F: 150 W
RG-PA150I-F: 150 W
RG-PA1000I-P-F: 176 V AC to 290 V AC, 1000 W; 90 V AC to 176 V AC, 930 W (PoE: 740 W)
Frequency: 50 Hz/60 Hz
Rated voltage range: 240 V
LVDC input:
DC input:
DC input:
LVDC input:
DC input:
DC input:
120 years
110 years
94 years
90 years
95 years
10% to 90% (non-condensing)
5% to 95% (non-condensing)
45°C (113°F): 57.1 dB
27°C (80.6°F): 50 dB
45°C (113°F): 65 dB
27°C (80.6°F): 53 dB
45°C (113°F): 68 dB
RG-S5760-X Series
IGMP v1/v2/v3 and IGMP proxy
Dynamic ARP Inspection (DAI)
REUP, RLDP, and DLDP
1+1 power module redundancy
NMS and mainten
ance
Syslog
RG-S5760C-48GT4XS-HP-E:
Protocol Compliance
RG-S5760-X Series
Organization
Standards and Protocol
IETF
RFC 1157 A Simple Network Management Protocol (SNMP)
RFC 1305 Network Time Protocol Version 3 (NTP)
RFC 1349 Internet Protocol (IP)
RFC 1350 TFTP Protocol (revision 2)
RFC 1519 CIDR
RFC 1591 Domain Name System Structure and Delegation
RFC 1643 Ethernet Interface MIB
RFC 1757 Remote Network Monitoring (RMON)
RFC 1812 Requirements for IP Version 4 Router
RFC 1901 Introduction to Community-based SNMPv2
RFC 1902-1907 SNMP v2
RFC 1918 Address Allocation for Private Internet
RFC 2131 Dynamic Host Configuration Protocol (DHCP)
RFC 2132 DHCP Options and BOOTP Vendor Extensions
RFC 2571 SNMP Management Frameworks
RFC 2863 The Interfaces Group MIB
RFC 2925 Definitions of Managed Objects for Remote Ping, Traceroute, and Lookup Operations (Ping only)
RFC 3046 DHCP Option82
RFC 3417 (SNMP Transport Mappings)
RFC 3418 Management Information Base (MIB) for the Simple Network Management Protocol (SNMP)
RFC 4022 MIB for TCP
RFC 768 User Datagram Protocol (UDP)
RFC 783 TFTP Protocol (revision 2)
RFC 792 Internet Control Message Protocol (ICMP)
RFC 793 Transmission Control Protocol (TCP)
RFC 813 Window and Acknowledgement Strategy in TCP
RFC 815 IP datagram reassembly algorithms
RFC 826 Ethernet Address Resolution Protocol (ARP)
RFC 854 Telnet Protocol
RFC 959 File Transfer Protocol (FTP)
RFC 1058 Routing Information Protocol (RIP)
RFC 1583 OSPF Version 2
RFC 1981 Path MTU Discovery for IP version 6
RFC 1997 BGP Communities Attribute
RFC 2236 IGMP
RFC 2328 OSPF Version 2
RFC 2385 Protection of BGP Sessions via the TCP MD5 Signature Option
RFC 2439 BGP Route Flap Damping
RFC 2460 Internet Protocol, Version 6 (IPv6)
RFC 2461 Neighbor Discovery for IP Version 6 (IPv6)
RFC 2462 IPv6 Stateless Address Auto configuration
RFC 2463 Internet Control Message Protocol for IPv6 (ICMPv6)
RFC 2545 Use of BGP 4 Multiprotocol Extensions for IPv6 Inter Domain Routing
RFC 2711 IPv6 Router Alert Option
RFC 2787 Definitions of Managed Objects for the Virtual Router Redundancy Protocol
RFC 2865 Remote Authentication Dial In User Service (RADIUS)
RFC 2918 Route Refresh Capability for BGP 4
RFC 2934 Protocol Independent Multicast MIB for IPv4
RFC 3065 Autonomous System Confederation for BGP
RFC 3101 OSPF Not so stubby area option
RFC 3137 OSPF Stub Router Advertisement sFlow
RFC 3509 Alternative Implementations of OSPF Area Border Routers
RFC 3513 IP Version 6 Addressing Architecture
RFC 3575 IANA Considerations for RADIUS
RFC 3579 RADIUS Support For EAP
RFC 3623 Graceful OSPF Restart
RFC 3768 VRRP
RFC 3810 Multicast Listener Discovery Version 2 (MLDv2) for IPv6
RFC 3973 PIM Dense Mode
RFC 4271 A Border Gateway Protocol 4 (BGP 4)
RFC 4273 Definitions of Managed Objects for BGP 4
RFC 4360 BGP Extended Communities Attribute
RFC 4456 BGP Route Reflection: An Alternative to Full Mesh Internal BGP (IBGP)
RFC 4486 Subcodes for BGP Cease Notification Message
RFC 4552 Authentication/Confidentiality for OSPFv3
RFC 4724 Graceful Restart Mechanism for BGP
RFC 4750 OSPFv2 MIB partial support no SetMIB
RFC 4760 Multiprotocol Extensions for BGP 4
RFC 4940 IANA Considerations for OSPF
RFC 5065 Autonomous System Confederation for BGP
RFC 5187 OSPFv3 Graceful Restart
RFC 5340 OSPFv3 for IPv6
RFC 5492 Capabilities Advertisement with BGP 4
RFC 6620 FCFS SAVI
IEEE
IEEE 802.2 Logical Link Control
IEEE 802.1ab Link Layer Discovery Protocol
IEEE 802.1ad Provider Bridges
IEEE 802.1ax/IEEE802.3ad Link Aggregation
IEEE 802.1D Media Access Control (MAC) Bridges
IEEE 802.1Q Virtual Bridged Local Area Networks (VLAN)
IEEE 802.3ad Link Aggregation Control Protocol (LACP)
IEEE Std 802.3x Full Duplex and flow control
IEEE 802.1D Spanning Tree Protocol
IEEE 802.1s Multiple Spanning Tree Protocol
IEEE 802.1w Rapid Spanning Tree Protocol
IEEE 802.3bt Power over Ethernet
Industry Certificates
Electromagnetic Compatibility (EMC) Standards:
✓CISPR 22/EN 55032 (Conducted and Radiated Emissions)
✓EN 55035 (Immunity)
✓IEC/EN 61000-4-2 or ANSI/ESD S20.20 (Electrostatic Discharge - ESD)
✓IEC/EN 61000-4-3 (Radio Frequency Electromagnetic Field)
✓IEC/EN 61000-4-4 (Electrical Fast Transient -EFT)
✓IEC/EN 61000-4-5 (Surge Immunity)
✓IEC/EN 61000-4-6 (Radio Frequency Common Mode)
✓IEC/EN 61000-4-11 (Voltage Dips and Interruptions)
✓IEC/EN 61000-3-2(Voltage Dips and Interruptions)
✓IEC/EN 61000-3-2 (Voltage Dips and Interruptions)
• Safety Standards:
✓IEC 60950/EN 62368
✓IEC 60068
✓RoHS or WEEE (Environmental)
Power Modules
RG-S5760C-24GT8XS-X
RG-S5760C-48GT4XS-X
M5000X-4XS2CQ
M5000X-4QXS*
4 x 40GE QSFP+ ports
600 W PoE AC power module
1000 W PoE AC power module
RG-PD600I-P-F
600 W PoE DC power module
Optical Modules
