The RG-N18006-X is the next-generation high-performance core switch launched by Ruijie Networks. Can be deployed in Internet and campus data centers based on service requirements.
RG-N18006-X |
Module slots |
6 (2 for supervisor modules) |
Switch fabric module slots |
6 |
Fan module |
Three fan module slots |
Power module |
Four power module slots |
Switching capacity |
28.8 Tbps |
Packet forwarding rate |
17,280 Mpps |
Large buffer |
Ultralarge distributed buffer design and 200 ms buffer for each port to prevent packet loss in burst traffic |
Dimensions |
442 mm x 956 mm x 308.4 mm, 7 RU |
49 kg (including the fan) |
Power supply |
RG-PA3000I-F: AC: 90 VAC to 290 VAC HVDC: 192 VDC to 288 VDC |
Ventilation type |
Front-to-rear ventilation |
Maximum Power Consumption |
19000 W |
≤ 200,000 hours |
0ºC to 40ºC (32ºF to 104ºF) |
–40ºC to +70ºC (–40ºF to +158ºF) |
Working altitude |
–500 m to 5000 m above the ground |
Software Specifications |
RG-N18006-X |
Virtual Switching Unit 3.0 |
Data center features |
VXLAN bridge VXLAN gateway BGP-EVPN VXLAN VXLAN mapping IPv6 VXLAN over IPv4 M-LAG |
SDN |
OpenFlow 1.3. |
Traffic analysis |
sFLOW IPFIX NetFlow |
L2 features |
Jumbo frame IEEE 802.3ad (static link aggregation, LACP, cross-card link aggregation, cross-device link aggregation) IEEE 802.1Q STP, RSTP, MSTP GVRP QinQ LLDP Static MAC addresses, address filtering, and limit on the number of MAC addresses |
IPv4 features |
Static routing, RIP, OSPF, IS-IS, and BGP4 VRRP ECMP Policy-based routing |
IPv6 features |
Static routing, OSPFv3, BGP4+, IS-ISv6, and MLDv1/v2 VRRPv3 ECMP Policy-based routing Pingv6, Telnetv6, FTPv6, TFTPv6, DNSv6, ICMPv6 |
IGMP v1/v2/v3 IGMP Snooping IGMP Proxy MLDv1, MLDv2 Multicast static routing Fast leave |
ACL |
Standard, extended, and expert-level ACLs Global ACLs Ingress/Egress ACLs IPv6 ACLs |
QoS |
Mapping of IEEE 802.1p, DSCP, and ToS priorities Port-based rate limit |
Independent switch fabric modules and independent supervisor engines to implement thorough separation of the forwarding plane from the control plane 1+1 redundancy for supervisor modules N+1 redundancy for switch fabric modules N+M redundancy for power supply modules and fan modules Midplane-free design to avoid single point of failures Hot swapping of components Hot patching BPDU guard/Loop guard/Root guard ISSU NSR DLDP FRR Micro-segmentation security isolation GR for OSPF/IS-IS/BGP BFD for VRRP/OSPF/BGP4/ISIS/ISISv6/static routing |
Network Foundation Protection Policy (NFPP) and CPU protection policy (CPP) to prevent protocol packet attacks Prevention against DDoS, ARP, and ICMP attacks DAI, port security, IP source guard, and protected ports uRPF RADIUS and TACACS user login authentication, password security, hierarchical user management, and password protection Source IP address restriction Function of not sending unknown multicast packets to the CPU Suppression of unknown multicast, unknown broadcast, and unknown multicast packets SSHv2, providing encrypted security channels for user login ITU-T Y.1731 Prevention against MAC address flapping Plaintext and MD5 ciphertext authentication for OSPF, RIPv2, and BGP4 packets |
Management |
Console/AUX Modem/Telnet/SSH2.0 CLI configuration FTP, TFTP, Xmodem, and SFTP SNMP V1/V2c/V3 NETCONF RMON NTP clock Fault alarm and auto-recovery System operation logging Traffic analysis Zero-touch provisioning (ZTP) Reliable network service (RNS), which probes specific services provided by the peer device to monitor the service availability Telemetry Buffer status monitoring and traffic microburst identification Port mirroring, traffic mirroring, and ERSPAN Physical ports on all line cards support the routing mode and IP addresses can be configured independently. Monitoring of fan modules and power supply modules |
Specification |
RG-N18006-X |
Safety |
● EN 62368-1 ● IEC 62368-1 ● NM EN 62368-1 ● NM CEI 62368-1 ● UL 62368-1 ● CSA C22.2#62368-1 ● GB 4943.1 |
● EN 55032 ● EN IEC 61000-3-2 ● NM EN CEI 61000-3-2 ● EN 61000-3-3 ● NM EN 61000-3-3 ● EN 55035 ● NM EN 55035 ● ETSI EN 300 386 ● FCC CFR Title 47, Part 15, Subpart B ● ANSI C63.4-2014 ● ICES-003 Issue 7 ● GB/T 9254.1 |
Environment |
● Select the chassisand supervisor module.
● Select the powersupply module
● Select the switch fabric module.
● Select the line card.
● Select the optical transceiver.
RG-N18018-X |
18-slot chassis (without power module), equipped with fans |
RG-N18010-X |
10-slot chassis (without power module), equipped with fans |
RG-N18006-X |
6-slot chassis (without power module), equipped with fans |
M18000X-CM |
Supervisor module of RG-N18010-X and RG-N18018-X. It is used in combination with type-C switch fabric modules and CB cards. |
M18000X-CM II |
2nd-generation supervisor module of RG-N18000-X and RG-N18018-X. It is used in combination with type-C switch fabric modules and CB cards. |
M18006X-CM II |
2nd-generation supervisor module of RG-N18006-X. It is used in combination with type-C switch fabric modules and CB cards. |
M18000X-CM X |
Supervisor module of RG-N18000-X and RG-N18018-X. It is used in combination with type-E switch fabric modules and CE cards. |
RG-PA2700I |
Power module of RG-N18000-X series (available for redundancy, AC, 2700 W, 16 A) |
RG-PA3000I-F |
Power module of RG-N18000-X series (available for redundancy, AC, 3000 W, 16 A) |
M18018X-FE-C II |
Type-C switch fabric module II of RG-N18018-X |
M18018X-FE-C V |
Type-C switch fabric module V of RG-N18018-X |
M18010X-FE-C I |
Type-C switch fabric module I of RG-N18010-X |
M18010X-FE-C II |
Type-C switch fabric module II of RG-N18010-X |
M18006X-FE-C I |
Type-C switch fabric module I of RG-N18006-X |
M18010X-FE-E II |
Type-E switch fabric module II of RG-N18010-X |
M18018X-FE-E IV |
Type-E switch fabric module IV of RG-N18018-X |
M18000X-36QXS-CB |
CB card, providing 36 × 40GE optical ports (QSFP+) |
M18000X-36CQ-CB |
CB card, providing 36 × 100GE optical ports (QSFP28) |
M18000X-18CQ-CB |
CB card, providing 18 × 100GE optical ports (QSFP28) |
M18000X-18QXS18CQ-CB |
CB card, providing 18 × 40GE optical ports (QSFP+) and 18 × 100G Ethernet optical ports (QSFP28) |
M18000X-12QXS12CQ-CB |
CB card, providing 12 × 40GE optical ports (QSFP+) and 12 × 100G Ethernet optical ports (QSFP28) |
M18000X-6QXS6CQ-CB |
CB card, providing 6 × 40GE optical ports (QSFP+) and 6 × 100G Ethernet optical ports (QSFP28) |
M18000X-48XS2CQ-CB |
CB card, providing 48 × 10GE optical ports (SFP+) and 2 × 100G Ethernet optical ports (QSFP28) |
M18000X-48XT2CQ-CB |
CB card, providing 48 × 10GE electrical ports (RJ45) and 2 × 100G Ethernet optical ports (QSFP28) |
M18000X-48CQ-CE |
CE card, providing 48 × 100GE optical ports (QSFP28), used in combination with type-E switch fabric modules |
M18000X-48DC-CE |
CE card, providing 48 × 200GE optical ports (QSFP56), used in combination with type-E switch fabric modules |
100G-QSFP-SR-MM850 |
100G-QSFP-LR4-SM1310 |
100G-QSFP-iLR4-SM1310 |
100G-QSFP-ER4-SM1310 |
100G-AOC-10M |
100G-AOC-5M |
40G-QSFP-SR-MM850 |
40G-QSFP-LR4-SM1310 |
40G-QSFP-LSR-MM850 |
40G-QSFP-iLR4-SM1310 |
40G-QSFP-LX4-SM1310 |
40G-AOC-30M |
40G-AOC-5M |
XG-LR-SM1310 |
XG-SFP-ZR-SM1550 |
XG-SR-MM850 |
GE-SFP-LH40-SM1310-BIDI |
GE-SFP-LX20-SM1310-BIDI |
GE-SFP-LX20-SM1550-BIDI |
Mini-GBIC-GT(F) |
