Suitable for SME network core and large-scale network aggregation
RG-CS86-20XS4VS2QXS-D |
Fixed Ports |
20 x 1GE/2.5GE/10GE SFP+ ports, 4 x 10G/25G SFP28 ports, 2 x 40G QSFP+ ports. One switch provides a maximum of 32 x 10G ports, 2 modular power slots, and 2 modular fan slots. |
Fan modules |
Dual pluggable modular fans, with front-to-rear ventilation channels Fan speed regulating and alarm function |
Power modules |
Fixed management ports |
One MGMT port, one console port, and one USB port |
Forwarding Rate |
570 Mpps/1260 Mpps |
Switching Capacity |
2.56 Tbps |
MAC Table Capacity |
32,768 |
ARP table |
16,000 |
IPv4 Unicast Routes |
16,000 |
IPv4 Multicast Routes |
4,000 |
IPv6 Unicast Routes |
2,000 |
IPv6 Multicast Routes |
16,000 |
ACL entries |
In: 2,500 Out:1,000 |
Number of VSU members |
4 |
440 x 330 x 43.6 mm (17.32 x 12.99 x 1.72 in), 1 RU |
Weight of the empty chassis |
4.6 kg (10.14 lbs) |
Dual-core CPU, 1.25GHz |
Storage |
Flash memory: 1 GB SDRAM: 1 GB |
Power and Consumption |
Power Supply |
Supported power module type: RG-PA150I-F AC input: Rated voltage range: 100–240 V AC; 50/60 Hz Maximum voltage range: 90–264 V AC; 47/63 Hz Rated input current: 3 A
HVDC input: Rated voltage: 240 V DC Maximum voltage range: 192–288 V AC Rated current per circuit: 3 A
0°C to 50°C (32°F to 122°F) |
Interface surge protection |
Temperature Alarm |
Supported |
Feature |
Ethernet Switching |
Super VLAN, Private VLAN |
Basic QinQ |
STP, RSTP, and MSTP |
LACP (IEEE 802.3ad) |
IP Service |
ARP |
DHCP snooping |
DHCPv6 snooping |
IP Routing |
BGP4 and BGP4+ |
IPv4 and IPv6 VRF |
IPv4 and IPv6 PBR |
IGMP v1/v2/v3 snooping |
PIM-DM, PIM-SM, and PIM-SSM |
MSDP |
MLD v1/v2 |
MLD snooping v1/v2 |
PIM-SMv6 and PIM-SSM v6 |
IGMP filtering, IGMP immediate leave |
Port traffic rate limiting |
Multiple AAA modes |
RADIUS and TACAS+ |
HTTPS |
SSHv1, SSHv2 |
Global IP-MAC binding |
SAVI |
Strict and loose RPF |
REUP, RLDP, DLDP |
BFD |
SPAN, RSPAN, and ERSPAN |
sFLOW |
NTP and SNTP |
FTP and TFTP |
SNMP v1/v2/v3 |
RMON (1, 2, 3, 9) |
Telnet |
NETCONF |
Cloud and SON |
20 x 1GE/2.5GE/10GE SFP+ ports, 4 x 10G/25G SFP28 ports, 2 x 40G QSFP+ ports, supports up to 32×10G ports, 2 slots for power supply module, requires at least one RG-PA150I-F power supply module, 2 slots for fan modules, 2 pre-installed fans (Purchase at least one RG-PA150I-F module.) |
RG-PA150I-F |
150W AC power supply module for RG-CS86-20XS4VS2QXS-D |
1000BASE-GT mini GBIC conversion module |
GE-SFP-LX20-SM1310-BIDI |
GE-SFP-LX20-SM1550-BIDI |
GE-SFP-LH40-SM1310-BIDI |
GE-SFP-LH40-SM1550-BIDI |
10G SP fiber module, applicable to SFP+ ports, max cabling distance: 300m |
10G SP fiber module, applicable to SFP+ ports, max cabling distance: 10km |
10G SP fiber module, applicable to SFP+ ports, max cabling distance: 40km |
VG-SFP-SR-MM850 |
25G fiber module |
VG-SFP-LR-SM1310 |
25G fiber module |
10G SFP+ connector fiber, 1m long, including one cable and two connector modules |
10G SFP+ connector fiber, 3m long, including one cable and two connector modules |
10G SFP+ connector fiber, 5m long, including one cable and two connector modules |
VG-SFP-AOC5M |
25G Base SFP+ fiber cable (including modules on both ends), 5m long |
40G-QSFP-SR-MM850 |
40G SR fiber module, applicable to QSFP+ ports (OM3/OM4 MPO interface, 8 core, 850nm wave length, max cabling distance: 100m(OM3), 150m(OM4)) |
40G-QSFP-LR4 SM1310 |
40G LR single-mode fiber module, applicable to QSFP+ ports, max cabling distance:10km (LC interface, 2 core, 1310nm wave length) |
40G-AOC-5M |
40G QSFP+ connector fiber, 5m long, including one cable and two connector modules |
40G-AOC-10M |
40G QSFP+ connector fiber, 10m long, including one cable and two connector modules |
