RG-N18010-E
Front Panel
Rear Panel
Eight line card slots,
M18000E-8SFX
8 x SFX 10GE ports
M18000E-8SFG
8 x SFG GE ports
M18000E-HCA
20 x 10GE optical ports
4 x 100GE optical ports
Low CPU usage Low CPU usage
Faulty Optical Port Isolation
Visualization Visualization
Virtualization Virtualization
Tài liệu
N18010-E
N18014-E
Supervisor module slot
Line card slot
Switch fabric module slot
14200 Mpps
21,000 Mpps
19.2Tbps
28.8 Tbps
Number of MAC address
XA card: 4,000
XB card: 10,000
XA card: 96,000
XB card: 256,000
XA card: 40,000
XB card: 96,000
XA card: 64,000 (shared with IPv6 routes)
XB card: 350,000 (shared with IPv6 routes)
XA card: 4,000
XB card: 4,000
XA card: 15,000 (≤ 64 bytes, shared with IPv4 routes)
XB card: 65,000
XA card: 2,000
XB card: 2,000)
 XA card:
Ingress: 7,000
 XA card:
Ingress: 28,000
Egress: 4,000
43.6 kg (96.12 lbs)
68.3 kg (150.58 lbs)
Supervisor module:
Line card:
Supervisor module:
Line card:
Flash memory: 8 GB
SDRAM: DDR4 4 GB
M18000E-CM: 60 W
M18000E-48GT4XS-XA: 85 W
M18000E-48SFP4XS-XA: 117 W
M18000E-24GT8SFP8XS-XA: 95 W
M18000E-32XS-XB: 149 W
M18000E-52XS-XB: 250 W
M18000E-12CQ-XB:240 W
M18010E-FE-X I: 50 W
M18000E-FE-X II: 160 W
M10C-FAN: 216 W
M18000E-CM: 60 W
M18000E-12CQ-XB: 240 W
M14FAN-F: 360 W
RG-PA600I: 600 W
RG-PD600I: 600 W
RG-PA1600I:
  90 to 180 V AC; 1,200 W
 180 to 264 V AC; power: 1,600 W
RG-PD1600I: 1,400 W
 RG-PA600I: 100–120 V, 200–240 V, 50/60 Hz
 RG-PD600I: –48 V DC
 RG-PA1600I: 100–120V, 200–240 V, 50/60 Hz
 RG-PD1600I: –48 V DC
 RG-PA600I: 90–264 V, 47–63 Hz
 RG-PD600I: –40 V DC to –75 V DC
 RG-PA1600I: 90–264 V, 47–63 Hz
 RG-PD1600I: –40 V DC to –75 V DC
≥ 200,000 hours
0°C to 50°C (37°F to 122°F)
S
oftware Specifications
RG-N18000-E Series
IPv4 and IPv6 GRE tunnel
MLDv1 snooping
MPLS L3VPN
MPLS 6VPE and MPLS 6PE
MPLS IPv6
IEEE 802.1p
IEEE 802.1X
IPv4/IPv6 ECMP
VLAN mirroring
FTP, SFTP, TFTP, and Xmodem
Web-based NMS
LAN access to VXLAN
IPv4 over IPv4
Distributed gateway
IPv6 over IPv6
VXLAN static route
Anycast gateway
VXLAN bridging mode
VXLAN routing mode
Static VXLAN tunnel creation
Layer 2 VXLAN bridge
Layer 3 VXLAN gateway
RG-N18010-E
RG-N18014-E
M18000E-CM
Power Modules and Fan Modules
RG-PA600I
RG-PD600I
RG-N18000-E power module (redundancy, DC, 600 W, 20 A)
RG-PA1600I
RG-PD1600I
RG-N18000-E power module (redundancy, DC, 1400 W, 50 A)
S
FUs
M18010E-FE-X I
M18000E-FE-X II
L
ine Cards
M18000E-32XS-XB
M18000E-52XS-XB
M18000E-12CQ-XB
M18000E-48GT4XS-XA
M18000E-48SFP4XS-XA
