RG-S6120-20XS4VS2QXS 24-Port 10GE Layer 3 Managed Core and Aggregation Switch (with Four 25G SFP28 Ports, Backward Compatible with 10G), 40G Uplink
  • Rich port types, 20 x 10G SFP+ ports,4 x 25G SFP28 ports, and 2 x 40G QSFP+ ports for uplink
Thông số chi tiết chính
Layer 3 All-Optical 10GE Core & Aggregation Switch
Recommended aggregation switch for large-sized networks, or core switch for small and medium-sized networks. With 20 x 10G SFP+ ports and 4 x 25G SFP28 ports, the switch provides flexible access capabilities. The 2 x 40G QSFP+ uplink ports deliver high-speed uplink connectivity, fully satisfying the requirements of
high-performance networks.
and Network Connectivity
Tài liệu
Basic specifications
20  x 1G/2.5G/10GBASE-X SFP+ ports*
x 10G/25GBASE-X SFP28 ports,
x 40GBASE-X QSFP+ ports,
Support up to 32  x 10G ports,
2 modular power slots,
2 modular fan slots
Management ports
1 MGMT port
1 USB port
2.56Tbps/25.6T
Forwarding rate
570Mpps/1260Mpps
Up to 16K
Routing Table Size
(IPv4/IPv6)
16K/16K
Up to 2500
Product Features
4K 802.1Q VLAN
Super VLAN
Link aggregation
LACP (802.3ad)
Port mirroring
Flow-based mirroring
Link aggregation mirroring
Spanning tree protocols
STP, RSTP, MSTP
128
DHCP Server
DHCP Client
DHCP Snooping
DHCP Relay
IPv6 DHCP Snooping
IPv6 DHCP Client
IPv6 DHCP Relay
IPv6 protocols
BGP4, BGP4+
Policy Based Routing
IGMP v1/v2/v3, IGMP proxy
PIM-DM, PIM-SM, PIM-SSM
MLD Snooping, MLD
ACL &
Various hardware-based ACLs:
Time-based ACL
Port-based speed limit
8 priority queues per port
SSH
BPDU Guard
CPP, NFPP
Up to 2 stack members
Physical Specifications
Rated voltage range:
100 to 240VAC; 50/60Hz
Maximum voltage range:
90 to 264VAC; 47/63Hz
Rated input current: 3A
Rated voltage range: 240VDC
Rated current per input: 3A
<85W
Power Surge Protection
4KV (MGMT Port)
Temperature alarm
0°C to 50°C
Storage temperature:
-40°C to 70°C
Storage humidity: 5% to 90%RH
0 to 5,000m
(W x D x H) (mm)
30 Years
GB4943-2011
EN 62368-1:2014+A11:2017
Emission Standards
GB9254-2008 CLASSA
EN 55032:2015+AC:2016
EN 61000-3-2:2014
EN 61000-3-3:2013+A1:2019
EN 55035:2017
* Support on latest version 12.6SPJ2
